182 / 172 front hubs & geometry problem
Car  Clio 182
Hi all,
I have fitted a 172 front left wheel hub to my 182 (non cup pack) as part of a repair, but now the camber of that wheel is way out / positive.
Are the 182 non cup and 172 wheel hubs the same? I still have all the other 182 suspension components in.
I have tried tweaking the subframe positioning as that was also removed, but it didnt do much.
As the camber is non-adjustable on this car with the 54mm front hubs, im out of ideas, any help would be appreciated.
The car has also had new control arms/ball joints, as part of the repair.
Failing a traditional fix, what are my options? Could I fit coilovers and camber bolts to adjust it that way?
Thank you :)
