182 emissions fail
Car  182
Hi,
i have searched through some old posts but havn't found an answer.
My 182 failed on emissions today, it failed on its high idle test.
However it also failed due to having a major leak of gas from the centre silencer, this turned out to be a hole in the side, i will be getting this fixed.
Could this affect the test? i'm hoping it does, but it is after the lambda sensor so it isnt really effecting the gases?
so i'm thinking it will probably be the cat? or sensors?
any help appreciated?
if it failed on the lambda readings then this would be caused by the leaking exhaust as the blow will draw air into the exhaust system causing the emissions probe at the back of the exhauts to think it was running lean
also how hot was your engine when they tested it as a cold engine will give false readings...normally i will let the car tickover for 5 mins before i test it
dont really understand the readings
fast idle
HC 7 ppm
Lambda 1.14
2nd fast idle
HC 3 ppm
Lambda 1.14
is that them??
In summary results it says
fast idle
Lamb (0.97-1.03) fail
2nd fast idle
any use?
so can fixing the hole fix this? (even though it is after the cat and lambda's) cleaning the lambdas? giving the car a good drive?
or is it going to be an expensive one? lol
if you still get trouble with it just ask the tester to run the car at 4.5k for about 20 secs,that should then bring the reading down..thats what i normally do when testing cars that are having trouble going through and it normally works..failing this a bet test should get it through
