182 headlight washers
Car  BG 182,megane td
my headlight washers have failed (again) so am going to ditch the blighters,wherecan i get the cup covers?
As I understand it (although I don't have any myself, thank god!) the one-way valves fail and then they leak by syphonic action from the bottle - somebody recommended fitting aftermarket one-way valves of a better quality, into the tubes...
That's the worse thing about them leaking, they drain the rest of the bloody washer bottle :mad:
Really it will fail an mot ???
I've got some cf washer blank's coming soon :(
Indeed, if the tester follows the rules... Xenons where present should be washable. But then how many chavs who fit them aftermarket onto their cars install washers? Unless they change them back pre-MOT... :S
I'm in two mind's whether to fit them now i get my car mot'd at renault so could imagine that they will be harsh on the rule's infact it might be worth getting a pre mot check ;)
Yeah it depends on the place that does the MOT.
I'd like to get rid of mine, as i never use them.
i never use mine, only cause the last time i did they didnt stop- leaking for a few days.. now they stopped leaking im scarred to use them again
