Barron
Turbo S,Exige,R5,182
got a few questions after buying a 182 manifold
1. I will be either coating or heat wrapping the manifold before fitting, obviously this will lower the engine temp. slightly. Im woundering if this will have any effect on the engine as are they programmed to work best at a required temp. or is it ok dropping the temp with heatwrapping?
2. I will be fitting the manifold along side a custom made exhaust with a decat.
i. Am i ok running it on the standard ECU setting for awhile without it being remapped?
ii. Should i bodge a 172 cat to fit ready for MOT time or should i just buy a 182 cat? (182 cat is lower cell rating isnt it though?)
3. 182 Manifold + SS exhaust/Decat + ITG filter + remap = ??? bhp (just an idea
thanks for your time
/Carl
/Carl
