182 misfire
Car  Clio 182
Having a strange one with my 182, developed a missfire at around 3k RPM cruising speed, initially thought spark problems so put leads, plugs and a coil on still no change, checked it wasn't drawing in air anywhere all ok, unplugged the MAP sensor and it was running rich but the missfire was gone, replaced the MAP sensor and cleared codes the fault immediately came back, put my sensor in a different car and it's running fine, any techs on here recommend what to try? Or have a pin out wiring diagram for the PCM, im stummped with it
