Whats the easiest way and whats needed?
F Friction Mk2 Ph1 1.2 8v Aug 3, 2005 #2 warm engine up, drail oil via sump plug (8mm sump socket), replace nut and washer. Change oil filter, refill with oil... nothing to it
F Fred@BTM Lionel Richie Aug 3, 2005 #3 remove the fuel rail cover (the big heat sink thing at the front of engine) this makes removing the oil filter easier new filter FROM RENAULT is about £7 plus washer for sump plug = £0.50 new oil 5W40 FULLY SYNTHETIC = £30-£35
