182 Performance
Car  Civic Type R EK9
Do you think its just because im not used to it?? but i dont think my 182 feels that fast for sum reason
check if the CAT to centre section is blowing, this has a dramatic effect on performance (more than a usual blowing exhaust)
^^ would explain why mine felt faster after redoing the cat gasket, you get my pm fred?
i had a civic type r wasnt much faster just felt it!!
Fred hows the best way to check this?? i will go look now
erm stick yer head under the car with the engine running and get a mate to put his hands over the tailpipes
Yeah, mine has been like that for a while and im just too lazy to get under it. Will sort it next week. Oh, and while your here fred... do you have any of those single piece clamps for that section and not the 'upgraded' 2 piece clamps renault now provides ?
yeah if you've got hissing you have a leak, its best to do it in the morning when the car is stone cold as you'll see water dripping from the leak
Does this apply to 172 exhausts too? Because I think mine may to blowing a little. There is also some black stuff (looks like soot, so carbon deposits?) in a spread-out-fan pattern on the pipe where the exhaust joins the CAT. Not a huge amount, but it's there.
it doesn't seem to effect 172 for some odd reason, its only been noticable on 182's
still no car should have a blowing exhaust
black soot around joins = blow
I would imagine its blowing then mate as how else would it be there the exhaust is obviously sealed until end.
I dont think mine is blowing the car has only done 15000 and is in mint cond
its quite normal for 182's to have a slight blow
nearly every 182 i've seen has a slight blow between manifold and CAT
yeh i will leave it until its really noticeable!! also fred is decatting worth it with std exhaust will i notice performance diff etc?
Get a Yozzasport cat back system on and you'll be laughing it frees up the engine no end...single best mod i've ever done...it flys up the box with a rather nice tone to it...
A quick vid of mine:
we use a 2piece one on it Justin, but we silicone the joint first
Silicone. Thats an ace idea !! Is there anything special i need to look for or just regular silicone. Is it not effected by the heat fred ?
The reason i thought the single piece was better is because its been rubbish ever since the 2 piece was fitted and ive relocated it more times then i could count, without any real chane.
Think ill have another go over the weekend as its sounds very 'farty' just now unless i gun it everywhere lol
most places use silicone these days, i just nicked some of the bathroom silicone sealent that my mum had lol
type r feels faster cos it has none .....then lots.....clio has some then more...get ma drift...hot weather too makes em sluggish...low air pressure n the like
Fred, when I had my system fitted and went to see Yoz a few weeks after he drove it and said "Its really responsive". Direct quote. I'll never forget them words.
So how much does a decat actually gain you reckon?
