182 precat lambda part #
Morning all,
I've searched the forum high and low for the part number for a precat bosch lambda sensor but can only find the more expensive NGK/NTK.
I think this is the correct part?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400074425991
Part Number: 0258006046
Short Code: LS6046
Type Formula: LSF-4-21
Sensor Location: Front
Number of Cables: 4
Length (mm): 480
Service Interval (miles): 100000
This lambda sensor is listed by Bosch to fit the following models:
RENAULT Clio II 2.016V 03.03-10.07 166BHP (124Kw) F4R 738​
pre-cat and after cat are the same,
part no: 7700107433
if the pre cat has failed swap it with the after cat till you get a new one.
cheers guys much appreciated :cheers:, thought they were the same in all honesty and I will be swapping them around temporarily thanks
