182 Rear Shocks Adjustable - Opinions?
CrashBurnFly
Car  various
As one of my standard ones is weeping I will need to replace. I would like to fit an adjustable pair of rear shocks to be able to fine tune suspension setup and a forum search did not show much so thought I would ask for views on makes/options? I would like to be able to adjust compression and rebound.
182 currently on standard front and rear factory suspension/ride height.
You want separate compression and rebound?
Not a standard feature if so.
Koni sport ones are adjustable damping. They will work with uprated springs. I'd probably run them full soft for road use though.
Most companies focused on coilover kits for the Clio so theres not really a lot available
