2.0 conversion
Car  clio f7r with bodies
hey just a simple question, which im sure has been asked a million times, but i have searched and could not find the answer.
basically i have a valver and am sourcing a 2.0 willy engine to put in it, just want to know what i need for the swap, ecu i know, do i need to get a loom? any other bits needed? oil cooler neccessary? replys very grateful.
You can use the Valver loom I think. If not use the Williams loom and ECU plus you need the alternaotr or starter plus gea gearbox isn't a bad idea although 16V one is fine. Somthing about the flywheel rings a bell needding to use the 1.8 one with a 1.8 gearbox. Coil cooler isn't a bad idea some Williams come with one.
Its been answered quite a few times reciently so work having another search.
