2 Stroke Oil mixed with Diesel
The way a Diesel engine operates, the clattering noise means it is working properly
If you put two stroke oil in with the diesel, it is less volatile so will effectively slow down the combustion process making the engine quieter.
But that doesn’t mean it’s better, in fact it’s worse.
Nah one of my injectors is on its way out but I’ve been neglecting it because I’ve got a 172 still without an engine in it and about £1000 worth of parts still to be bolted to it[emoji23][emoji23]
Need to do a leak off but I’ve got the cambelt to get sorted next week[emoji849]
Yeah diesel isn’t volatile, you can sit and throw matches and lighters at a diesel spill all day without it doing anything. Compress it and heat it to above 200 degrees and then it’s a different story
But even if you compress engine oil and heat it to a certain degree it will become volatile, same with most stuff. You could probably get a jar of someone’s piss to burn if you really wanted
I also seem to think that some people are forgetting we’re not running our cars on 100% 2 strike oil, it’s a very very dilute mix to put some Lubricity back in as sulphur is no longer in diesel.
Fair enough if you want to do it, then do it.
The discussion on the Land Rover forum went to ten pages with no definitive yes or no.
Some mechanic even said that the two stroke oil didn’t mix with diesel and he’d found pools of the stuff in the bottom of fuel tanks.
Land Rover’s will run on 5w-30 so why would you bother with 2 stroke.
2 stroke on common rail = yes makes a slight difference
2 stroke on IDI = not much point
Early Land Rovers yes up to 300tdi
But TD5 and particularly TDCi demand more care when glugging random substances in with the fuel.
Horses for courses really,
I use 2 stoke in my old smokers but not in the new 330d (warranty so not bothered)
Lucas pumps will last longer with 2 stoke added as their internals are made from chocolate,
Bosch VE and inline pumps don't give a s**t and will happily pump mucky sludge all day long without issues so possibly less benefit.
TD5's were run on jet fuel in Iraq by the US military with a bit of 2 stroke in it
Delphi stuff ain’t good unless you’re careful
Been toying with the idea of getting rid of my dCi ad getting something more grown up. Can’t bring myself to get rid though[emoji30]
that article was interesting. Amazing if it really does reduce the lubricating properties. Would like to see some more evidence to compare it against.
Something slightly more legit than an article on a random website, it looks fine but it doesn't appear anywhere else online and you'd expect it to be referenced in a journal somewhere??
Interesting this - as the OP says, if you're doing this on your cheap daily and the overall results look and feel better, then great.
I wonder if with less smoke generated, the results from the exhaust come MOT time would actually be better?
Given that visible smoke is now a fail I think it would probably help come MOT time.
It’s the particulates not a visible test iirc
And I think it only heavily applies to newer diesels, they still can’t be as strict with the older diesels due to a lack of DPF, there are always going to be particles present on an old coal burner[emoji23]
But saying that mine ain’t the cleanest of burners and mine was well within the new MOT ruling... dunno what it’ll be like when I say bye to the cat[emoji102]
Nah I sold my clio on 250k and the Megane is a nice 'new' diesel so the low sulphur diesel doesn't do much in fuel knock
Ran the same mix in my dads Astra until it shat a valve and he'd done well over 150k in 5 years doing the same thing. Anything pre 2004 and 2vPC will love a bit of 2 stroke
It’s on 128k. Fairly well serviced but doing circa 500 miles a week.
Doesn’t smoke as it is so will run a few tanks through.
Mpg is down because the thermostat is stuck open. Noticed it more over Christmas when the temperature was constantly at freezing. When I get round to doing the thermostat I’m hoping that will make a difference!
