2005, 152,000 few faults. Please help
Car  2005 Mondeo ST
Morning all
as some of you know I was given a 2005 Clio with 152,000 on the clock. (first car for misses)
I have overhauled lots of it like, Clutch, bearing, clutch cable, gearbox oil change, cleaned all engine earths, cleaned abs rings / sensors, oil / oil filter change, air filter, Ing pack, HT Leads, Spark Plugs, V belt, all engine Mounts, Radiator and coolant flush / change, cleaned crank sensor, removed sunroof and resealed, removed front discs and callipers and re-greased pins and replace discs, All genuine Renault parts used
Right now on to the on-going faults
1, under normal light breaking i get a hollow knocking noise, (only under normal breaking) heaving braking nothing, and driving nothing
2, ABS light / service light has recently come on, sometimes goes off,
3, gear stick rocks when lifting off acc pedal
4, interior light not working, (boot light works, all dash lights work, radio works, checked fuses on pass side and all look okay)
5, when switch hazards on the open door light come on the dash
6, auto lights stopped working
7, Passenger hub has two threaded holes (need to go scrap yard)
Thank you all for any comments / advise. I want to get all sorted soon as her test is in two weeks
3 sounds like worn engine mounts. Mainly lower mount
To fix 7, with the engine off switch the lights on and off a few times
All mounts are replaced when I removed the engine to do clutch and service, could it be the gear linkage? I belive there is nylon washers in there, are these replaceable? will try 7 Thanks
I think @bertieg means 6. Not sure how flicking the light switches will fix a hub :tongueout:
And the owner's manual way to turn auto lights back on is to turn key to ignition (engine off), flick sidelights on, sidelights off, sidelights on, sidelights off, turn key to off position. Turn the key to start; engine and lights turn on :smile:
2. Sounds like a broken abs ring. Friend has the same problem. His is definately a broken ring.
