I've just had my front tyres changed to wider than my rears, now they're worn in I don't like it. Same as you, 205 PE2s and 195 eagle f1s. Great turn in, but it's not confidence inspiring around long bends at speed. The back felt very light last night and a bit skippy, although I was covering ground quite quickly.
Also now lowered, my fronts are scrubbing when taking corners quickly so am going to put my 195s on the front and 205s on the rear, as the 205s will have a bigger circumference as well as width this might help. Not sure how this will affect handling, I'd assume it'd cause more understeer which I'd probably prefer anyway. 195s might let me run a bit more camber so hopefully even out.
