20mm+ Coilovers
  2002 Clio Dynamic
Which company makes coilovers that lower from 20mm+ and what model are they?
Need to find a set that lower from 20mm or as near to!
  2002 Clio Dynamic
Im looking for a set of coil overs but i need to be able to lower the rears 20mm so need a set that can start off that high if you like and then still let me lower the front 40mm+
  2002 Clio Dynamic
I dont want to go lower,i want to find a set that start off higher than 40mm so that i can only lower the back 20mm and still have the fronts 40mm
  2002 Clio Dynamic
I cant go as low as poss since the weight of my install make the back end go right out of proportion with the front so a 40mm front,20mm back set up works best as i also need to be able to get over all the speed bumps in my estate!
And i want Coilovers just for the sake of having them too
  2002 Clio Dynamic
It was a 1.4 Dynamic but i have had a 172 engine put into it so now i have the front suspension and brakes of a 172 as well so kinda makes it a 172/dynamic Hybrid thingy!
