172 cup
as above ^^^ when i set my alarm after i get out my car every now and then it beeps 3 times anyone know what it is?
Matty
Matty
^ does that work on mk2 phase 1 cars ? (a mk1 vee)
My alarm always goes off with the slightest vibration, it's the ultra-sonics that are over-sensitive.
Its when you stop the car, turn ignition off and then back on again, then when you lock it, it lets you know that the ultrasonics are not on.
Alarm will work if door is opened, but if window is smashed, unless the door is opened, then the alarm won't go off.
Useful if you want to leave your windows down a touch if its really hot while still keeping the car locked and reasonably secure.
I don't know Craig. It works on Cups...but doesn't (seem to) work on Curley's 182...as I tried it to show him how it worked. Sure someone on here will know about the PH1's.![]()
Bumpage,
any one know if you can turn the sensors off ? I know for sure that my alarm will keep going off at FCSand i'm not leaving in un locked.
I had a quick look at the sensors last night, but they only have one black wire going to them.
Not quite.
Stop, open door, insert key, ignition on and off twice, close door and lock with the fob as usual. This dis-arms the sensors.
IIRC you can also just lock it with the key in the door and this locks the car, but won't set the alarm?
I do this everytime I wash the car as well btw, as mine sometimes goes off when washing it, poss due to vibrations.
Best thing to do is open the passenger side door and press the swith on the dash to lock all doors, close passenger door and lock with key - all is secure then.becarefull when locking the car with just the key, i tried this out of interest and when i lock the car using the key in the drivers door, it ONLY locks that door, the other door and boot remain unlocked
