Right,
36K including aux belt,
£380.22
3.8hrs
This includes,screenwash, oil & filter, air filter, pollen filter, new aux belt, (if you have an aftermarket air filter this will be deducted accordingly!
You could arange a courtesy car if required, assuming your over 23 (insurance)
36k service involves :
Check front and rear washers/wipers, quality etc etc
check condition of panelwork, doors mirrors, glass etc etc
check seatbelt mounting/operation
check horn operation
check all exterior lights function
check interior lights, heater panel etc
check vehicle bodywork, anti corrosion
check condition of front & rear discs & pads, with wheels removed.
check condition and mounting of exhaust
check steering ball joints, track rod ends, driveshafts for play, and gaiter condition
check for leaks (visual) of any fluids
Check and test antifreeze strentgh
check and test brake fluid (brake fluid attracts moisture, as it gets older it becomes less efficent (SP) boils quicker than it should)
check shock absorbers and springs
check tyre pressures and record tread depths
check under bonnet levels and top up if required
check a/c operation
complete service book
carry out basis diagnostic check using CLIP.
Think thats it, i apologise for the bad english, i may have missed a few things, thats from memory!! you get the idea!
