Hey all,
Does anyone know if its possible to do this conversion on a clio sport? Wanna get some 5 spoke alloys in a 5 stud fitment but they don't do the same ones in a 4 stud. Surely its a case of changing over the brake discs and hubs?!? Thanks
Yep thats all you have to do.
But all is a big word you need to get the ABs system to work the same.
You can get adapter plates made up which scre into the hub then give you the 5 holes etc that you need.
http://www.venommotorsport.com/shop/index.html click on wheels then PDC adapters, the vauxhall ones will fit as they are the same Pdc, just make sure the wheels you buy come with a vauxhall fitting kit (sprigot rings) you will need a 10mm smaller offset wheel too so they dont rub
