4 Rotors
Dicky Belly
  Whichever has fuel
Can someone explain
a) What the fcuk is that??
b) Why does it sound soooo good?
c) Why that man didn;t wear suncream?
Matt Cup
  Leon Cupra, 172 Cup
What. A. Noise.
  Ph1 Clio V6, Ph2 172
Answer
A) Thats a 4 rotor rotary engine based on Mazda parts. OEM engines were fitted with either 2 or 3 rotors as well as turbo charger. I'm pretty sure that particular car is campaigned in the U.S Time Attack Seires.
B) This is a tuned naturally aspirated one which means its making stupid ammounts of power. It sounds different to normal RX7/8's because of the extra rotor, lack of turbo, and the porting carried out on it. (Refere to 787B for similar bad ass noise)
C) God knows....he's a yank.
Matt_90
  Sprint/climb 106 gti
Remeber seeing a video of this a while back.... a truly awsome noise.
  TrackCar & F30 330d
Sounded like it was ideling at like 4K.
So loud too. I bet they have to noise test the engine not the exhaust!
MaLicE
Honorary Member
  Lazy v8
its a periphial port 4 rotor, they idle at 3.5-4k, it wont be making much over 450bhp as its na, pretty much all 4 rotors sound like that and rev so quick its mental... to build a 4 rotor engine just to buy the e shaft (basically the crank) your looking about £14k then you need 2 20b centre plates (about 1k each) and 4 rotors and housings (400 for new housing and 250 for new rotors EACH) then you need to build the manifolds (inlet and exhaust) which will prob set you back 1-2k, and then all the fueling (you need 8 injectors) and an ecu to run it... you would need a good 40k to do it cheaply... search on youtube for Mad Mike he drives a turbo'd 4 rotor fd3s rx7, makes 900bhp at low boost and he uses it for drifting (drifts for redbull team) to build a car that will handle the power you are looking at 50k plus for the engine etc if you already have the car... we talking massive money to do it right!
mad mikes car is a good 100k to reproduce. but nothing on the road will rev like it or drive like it, it would destroy zonda's etc... and im not bullshitting.
Christopher
  Z4M
4-Rotor is legendary.
Mad Mike's 26b is mental... and like Malice said, cost huge dollar to build.
But the daddy is the 787B. The idle gives me wood.
Gally
Sounds broken with an air gun in the background!
WTF!
  Turbos.
How reliable are the 4 rotors then? Probably going for a K20 or K24 conversion at the end of the season, but would love a 4 rotor if i could find evidence that they are a) reliable b) parts are plentiful and c) rebuild-able by any competent engine builder.
Christopher
  Z4M
It's basically two engines sharing the same eccentric shaft. So they're no more or less reliable than a two rotor.
That said, most 4-Rotors are far from standard. The 3-Rotor 20b from the Cosmo would be a better bet.
  172 Ph1, 1972 Mini 1
They arent really any of those, there are only a few UK companies who can do bridge ported 4 rotors in the UK, Dragon Performance being the main one. Reliability wise they are pretty similar to a 13B 2 rotor if running N/A, boosted power goes through the roof and life comes down accordingly. Parts wise most of it is standard peripheral port 13B except the special adapter plate and bespoke crankshaft.
MaLicE
Honorary Member
  Lazy v8
dragon havent made a 4 rotor so that above comment is rubbish lol!
WGT made a 4 rotor and guy uses it in sweden for time attack and as far as i has had no issues...
if you were gonna run a rotary for a race car i would be seriously concerned about noise limits... its very hard to make a rotary quiet or under noise limits... if you go na the throttles make a s**t load of noise but the exhaust is the main issue! if you make the exhaust quieter your adding restriction and rotaries shift so much air restricting it has a big knockback on power :(
Yeah sorry it was Rotary Art i was thinking of, they are doing the shafts for 2.5K
N/A 4 rotors give good torque and horsepower with mental throttle response which is why mad mike uses one for drifting, if you wanted to go circuit racing wouldnt a 13B turbo be better suited, more readily available, quieter, cheaper to get similar power to a N/A 4 rotor and the lag wouldnt be such a problem on a race track.
  Turbos.
What was the spec of the Le Mans car then?
N/A makes the noise, doesn't it? Turbo's aren't great for race cars really, not good power delivery, poor throttle response, heat issues...
  Turbos.
Whats the difference between a tuner one, with a 'mere' 450bhp then? Was it a completely different engine?
What about the short stroke version? Was reading something about it last night...
MaLicE
Honorary Member
  Lazy v8
it will be down to porting and delivery i guess, there is alot more money in the mazda team to spend on le mans engine dev than there is in the uk or anywhere else in the private sector to make the same advances... plus a le mans engine only has to last 24 hours lol
MaLicE
Honorary Member
  Lazy v8
tbh a 2 rotor with a t51r or t70 or t80 etc boosts and hits full boost (1bar) about 3-3.5k.... on street ports... a quad rotor with a t51 or t70 etc would be on full boost about 2k lol! so would be good for racing :) but i would wanna do a quad rotor with 2 t51r turbo's would be well over 1000bhp
