438 Cams and standard map
  Iceburg 172 ph2
Can the 438's be run on the standard Renault map for a short time or has the ecu need to be mapped to suit at the same time ? Thanks
  DON'T SEND ME PM'S!!
as above, stay in lambda controlled areas (for simplicity sake, sub 4k and sub 50% throttle) and use the highest octane fuel available. Don't leave it too long though
  Iceburg 172 ph2
Ok thanks for that guys only ask is im too far away from Ktec so will have them delivered then mapped locally. Thanks again :)
  Iceburg 172 ph2
Yeah unfortunately it is a fair distance between us, I would have jumped at the chance of you mapping it for me if you were closer :(
