yep might as well just drop a 1400 engine and box in, looks exactly the same as the 1200 as well so its up to you if you want to tell the insurnace or not.
...or you could just drop a 1.2 gearbox inot it, i have a 1.2 special deition oasis, they had 5 doors, sunroof and 5 gears, i woudl say that would be easier
1,D7F-has a plastic inlet manifold that curls over the rocker cover etc.
or
2,E type engine.rocker cover visible and has energy written on it in white letters.
if your 1.2 is a e type engine then a 1.4 engine visually looks exactly the same so you could do a engine swap and it would be very unlikely that anybody would find out.
Yeah i have an E type engine, can see rocker cover only plastic is the airbox!
how much could i find an RT engine for and what would i be looking for as obviously i cant see it running and as much as i would like to take sombodys word for it you never know for sure do you!
get the engine from a large breakers company so you get a few days warranty.gives you time to fit it and make sure its ok.a complete running engine should cost a couple of hundred quid at the most.
