If or when the cam belt was replaced the timing may not have been lined up 100%, in turn it can mess up the VVT.
Tbh I think I did notice a little lift but wasnt sure what to expect. Renault themselves did cambelt so assume they'd no how to do it correctly
Its prob me just being paranoid having saved to get a 182 I want to make sure its running as it should. As said seemed to pull throughout and exhaust made a nice sound although im sure its standard. Car could be remapped for all I know tbh.
What does the car rev to? A sign of a car being mapped is an increased rev limiter at 7800 RPM
I feel the 5k kick more thank i felt the turbo kick in in my corsa vxrs tbh.
Both my vxrs must have been broken.
How does yours feel mate as I did a thread about this before as I too was concerned. Mine just increases acceleration, which is noticeable, but is not that different feeling wise.
It increases in acceleration and sound slightly.
If you can feel something, then its probably fine, its not like you get smashed up the arse from a rocket or anything.
Is it???
Didn't think that all cars that where mapped reved to 7800?
I also thought that if reving to 7800 you needed to fit ARP rod bolts?
As far as im aware of that generic maps have a raised limiter of 7800
Engine dynamics map is 7500
Yeah ARP bolts is a good idea. I remember telling ya ages ago I was going to get some but there a pain to fit aint they
Ill let you know, i have a set going into mine.
The old R-Sport ECU had the 7.8k limiter, also I think the old RSTuner maps did. Generic maps are set at 7.5k nowadays though IIRC.
My 182 used to kick noticeably and the tone of the engine changed at 5k. My 172 didn't quite so much, that said NWP had changed the cambelt and f**ked it up so that would probably explain that one.
From what I've seen RSTuner still raises to a 7.8k rev limit.
When I map customer cars, it's 7500 unless they have ARP's and cams then it's 7800. I had a car in this week that had been mapped by someone else with the piper cams, and that had a 7900 limit on stock bolts!
7900 on stock bolts, fcuk that!!
Noticeable in which way?
You could feel it start to pull harder, and the engine tone would change slightly.
Non AC cars are easy. AC cars require slam panel off. Most difficult part is getting the sump bolts off without them rounding off usually.
