5mm spacers...would you bother with longer studs?
  Vectra :(
Need to add 5mm spacers to my rear alloys to stop a slight rub when turning on the left hand side.
If i was going above 5mm i would def get longer studs but will it matter if only spacing 5mm?
Whats peoples thoughts?
  Vectra :(
Is that a yep get longer ones or i may die or yep use what i already have and i will be fine? ;)
  Vectra :(
Ah bugger! Means *****ing about now finding somewhere that sells ones 5mm longer than i have :mad:
Cheers tho matey
  Burgandy 174 sport t
I wouldnt bother I ran about for about a year with 5mm spacers on original bolts, up too you thogh.
