60mm
yeah. but cant get 60mm springs can you ? just coilies for that kinda drop on a 172 i think
im sure that the most u can get is 40mm apex springs & then if you want to go lower you need a set of coilovers. sure someone witha sport will be along to give better advice on that. try the search button bud :). Might get some answers in there
40mm apex springs are the equivalent to 60mm non sport lowering. Sports are lower then no sports so works out the same. Your car will be perfectly ok lowered that much on springs
