definate remap fella...probably got a group n /rsport on it
Chris
I can do 120+ in 4th :s and easy 90 in 3rd!
Only work is matched inlets, Open IK and cat back exhaust! RSTuner for Xmas
As I said m8...defo remap or at least an off the shelf chip...if it was standard it wouldn't do 125 in 4th
Chris
Something's different there
Mine will do 110 jellybeans in 4th
From memory i can pull 120 with a set 7800 rev limit in 4th.
For you to get 122 - 125mph on a stock car it would have to be set at 8000+ rpm or no limiter at all lol so must be these aftermarket dials youve got maybe? rather than a re-map.
Not 100% but I think the phase 1 172s had a slightly different ratio box.....
Bust speedo?
If it is a group N/ Rsport Ecu it does rev to about 8k in 4th....slightly less in 3rd.....
Chris
Yeah the Rsport was a direct replacement for the standard ecu. I went to York with just an open ik and about 800miles and got a 15 sec dead 1.4mile....went back about a month later with the rsport added and got a 14.4 with full interior and standard exhaust so it does make a fair old difference.
TBH I vary rarely hit the full 8k except from showing people lol...the extra revs are quite handy on track for holding on to gears exiting bends for slightly longer
Sounds ok too
http://uk.youtube.com/watch?v=knvYsveN21g
Chris
15 secs on 1.4 mile?!?! You must have one of the 'fast' Clios!
Speeds in gears will not dictate wether not the car has had a remap. In gear speeds are dictated by the ratios. A 200bhp car will get the same speed as a 500bhp car if they were the same type of car with the same gear ratios.
lol well spotted..excellent contribution to the topic
Chris
