A leaking sunroof?
fill the surround of the sunroof with silicone so you cant open it, lets face it the sunroof is the worst part of the car
Talking about the manual tilt one?
Unclip it and take it off (takes 10 secs). Then check the drain holes are unblocked and use 100% (or as close as you can to, 100% is impossible....divers O-Ring grease cheap) silicone grease around all the rubber.
Don't cover the drain holes (OBVIOUSLY) and the roof rattle should be fixed with the silicone. Also tighten up all the star nut things. You can wrap some soft rubber around the "bar"/handle which can stop the rattle too.
One fix = free (or £3 for decent grease) and you keep your sunroof. Other fix £100s.
