A new light on the dashboard of the money pit
Car  Ph2 Flamer
Right so driving home and the below light comes on. Didn't fancy pulling over and calling the AA at 11pm and the stop light wasn't on so drove gently home and looked it up in the manual and read a few threads on here. So I understand its the emissions light which means something isn't right with whats coming through the cat or possible the post cat sensor is knackered? Or maybe the o2 sensor or my exhaust might be 'blowing'....
I guess the sensible thing to do is get it on a fault reader to find out whats wrong but am pretty skint this month what with new tyres, new track rods and the bloody cat (the animal) has been in and out the vets all week which is costing and arm and a leg. Soooo from the symptoms below I was wondering if they point strongly to one thing more than another and perhaps I can sort it without having to pay for clip.
Light is solid and not flashing
Comes on the second you turn the key and before the engine fires up.
Has not affected fuel consumption (if anything it's slightly improved)
Car drives perfectly well no change to how it pulls or sounds
Weather has been really wet if that can affect anything
Exhaust i don't know when it was put on and have no idea how to check if it's blowing - is there a noise I should hear or do i look under the car when its running?
Oh and am I completely mental to keep driving the car?
I drove around for 6 months with my engine management light on. But I knew it was because I had decat.
I'm currently rolling around with abs, TC, serv and airbag light on. Christmas tree dash FTW.
Post cat lambda on the way out/loose connection on knock sensor or just a change in the type of fuel.
My cup has done this when changing from sainburys to shell fuel.
My car ran fine with this light on.
PM me if you want to use my RStuner to check the fault.
You might find it goes out by itself then comes back on in a few weeks, that is pretty common if it's a failing O2 sensor but I would get it fault read.
My car passed the emissions test with the emissions light on, but only just.
Happened to mine, was pre cat sensor :) came on, few days later would go out again.
It will be pre cat more than post cat i would think
Could be anything really! If you was closer id let you use my scanner free. Ask a garage for a cash job to look at it, usually they just charge £10 - £20 as a back hander
