Hello all,
there are several threads on similar topics to this but I can't seem to find the exact answer.
So the issues I'm experiencing:
1. The car is just awful at very slow speeds (heavy traffic etc) Quite alot of hesitation at low rpm, stuttering/jolting. This clears more and more with rpm until at least 3k where it's smooth. The idle is awful as are most but I can't coast up to the back of traffic in gear with no throttle. The car bucks and kicks it's self to pieces. So far I had cleaned throttle body and tdc sensor, replaced 1st lambda and plugs.
2. Car pulls all over the place under power. Tram lines with any camber or the lines in the road. Two eagles up front, all engine mounts are ok, tracking is fine... Any clues?
3. A lot of lock or full lock, at low speeds, it feels like the front end is "skipping" "jumping?" as though there is a million degrees of caster and the front end is jumping around on the edge of the tyres but I don't think this is the case.
Any of this ring any bells with any of you guys?
2.
2.
