ABS Error code DTC 5006 "Front right wheel sensor likely failure
GavC
  Black Gold 182FF
I have the above present fault code on my 182, can anyone explain what it relates to? My searches reveal 182's only have ABS sensors on the rear brakes.
Cheers,
Gavin
Sent from my Nexus 6P using Tapatalk
  dan's cast offs.
sensors on all four wheels otherwise abs wouldn't work. look at live data and see what the sensor is showing compared to the others.
GavC
  Black Gold 182FF
Can you refer me to the part and it's location? Cheers buddy
  dan's cast offs.
  2014 Clio 200t edc
I had to replace one of these on my old 172. Pain as the bolt came out but the sensor broke needing the 'pole' bit in the hub drilling out. It didn't put up much of a fight against the drill though.
GavC
  Black Gold 182FF
Thanks guys I'll get the wheel off and check it out
