Hi guys.
Wondering if anybody can help with my abs fault before I have to give in and pay somebody to plug it in and get a code.
Abs light comes on at startup and doesn't go out, can also feel the pedal pulsing when braking.
So fault finding up to now..
I disconnected the rear sensors at the plugs next to the rear beam and pluged in the oscilloscope and spun the wheel.
Both rear wheels gave the same size sine wave reading so I'm fairly confident both sensors are functioning. Or is this not a good way to test them?
I did the same with the front right which also gave a solid sine wave, but stronger than the rears but I put this down to the different and rings front to rear.
I didn't test the front left as the Speedo works fine so can only assume the sensor is working correctly as I'm told front left is where the speed signal comes from as I have to gearbox Speedo
I need to check continuity from the sensors to the pump end of the wire but can't even see the bloody abs module. Where the hell is it?
