mikekean
996 C4S, 135i, E30x2
Thinking of fitting ABS to my rally car as in the wet the massive brakes just lock the wheels up if you even look at the brake pedal. Probably wont get used in the dry but id have the choice as it will be on a switch.
The modification I was thinking of doing was splicing the front a rear sensors together (per side) so that the ABS ecu cannot detect when the rear wheels are locked eg: when i pull the handbrake. But what i would like to know is will the abs still work? does it need the rear wheel input to detect when the fronts are locked or does it just go on if it senses lack of movement from the front wheels?
Mike
Mike
