ABS ring
  1.5 dci Expression
The abs light came on the other day so I had a look and found the abs ring had decided to destroy itself! Corrosion having got the better of it. I've had a look on the bay and there is someone on there selling the ring itself. I'm sure these are heat shrunk on and are definitely a lot cheaper than a complete shaft. Anyone used these yet?:S
Liamm
  Not anymore
My dad found some when my abs light came on, guy at the garage didn't know you could get the rings on their own, he was doing track rod end and a few other things under the car so just gave them to him. Make sure you get the right one though I'm sure there are two kinds with different amount of teeth on.
It didn't fix my abs problem but at a few quid was worth a try.
  1.5 dci Expression
Cool. Counted the teeth on the other side and got 44 so I'll change both sides! Thanks people!
