Accelerator Cable Snapped?
Scutch
Car  G87 M2, Megane R26
Was driving home in my mates Clio earlier and the accelerator pedal just hit flat to the floor, but with no power to accelerate. I pulled over and noticed that the cable and pedal was really loose. Looks like its either snapped or jumped out of place. Obviously I couldnt drive it any further so it had to be towed to a garage where they will see what the problem is and sort it out :dapprove:
Anyone else had this problem or know about it as a common fault? Costs, labour charges etc? Any help would be very appreciated.
Thanks guys.
sounds like its typical snapped throttle cable. Part is around £15 and relatively easy to fit. took around 30mins.
its reasonabley common on the MK1 172s... dunno about the lower specs...
Yeah snapped throttle cable. Not sure if its the same on the Renault but on the striker, the cable sits in a groove cut in the top of the pedal rod (bear with me) and is held in place by a locking bolt.
If this bolt came loose, it would be possible for the cable to accedentally pop out of this groove. Might be worth checking mate, although, to be fair, its more likely its snapped and £50 including cable is all it should cost.
yeah the early mk2 ph1's had accelerator problems, i got a letter from renult saying that they were recalling clios to have the cable replaced for free
Yeah its a 1.4 Clio. Well, £50 ish plus the towing fee, shame really as it shouldnt have happened. But alas... thanks peeps!
Just an update, throttle cable had indeed snapped. £16 ish, half an hour labour, and £20 ish towing charge. Oh well, thanks for the info guys! You were right ;)
