Accelerator Cable
  BMW F31
are these easy to fit?
i assume detach both ends and draw through bulkhead with the other one attached then reconnect?
any ideas on price from stealers?
Might be a daft question but your car definatly does have a cable throttle body doesn't as the 1.6 16V was made in phase 1 (ie cable throttle) and phase 2 (fly by wire) versions.
Its easy to chnage though yep stick some string on it before pulling it through the bulkehead. (so that you can pull the new one bac though to the cabin.
  BMW F31
fly by wire? not sure what that means. the throttle cable comes out of the bulkhead and curves round to the throttle body, the end looks like a push bike brake cable e.g cable with a metal piece at the end that locks into the arm on the throttle body.
Fly by wire means you don't have a bit ow wire between the throttle and the engine it woks instead on electrics.
But you yep you have a manual throttle body not to bad to do the swop as aI said above put a bit of string on the old one so when you pul it through the cabin bay to the engine you can pull the old one back with the same bit of string.
