Adjusting rear coilies?
Car  VRS
i need to tweak the height of my gaz coilies at the rear but im not 100% sure on how to do it.
can anyone help?
andy
jack the rear (not from the rear beam - from the rear sill jacking point would be fine i should think) and adjust the ring with the c spanners supplied
apparently u dont even need to remove the wheels....
You will need to locate the grub screw thats in the black collar (allen key head), and make sure its undone. Then adjust to height require, then lock up the grub screw. Job done. :)
