Adobe help !
  White Van Man
I've just been mailed a form in .pdf, that I need to fill in and return, but I can't type in any of the fields, anyone got any ideas ?
Thanks in advance
If you can't type in then the document must be set up wrong, as it should have form fields. Is your Adobe Reader update?
cant do anything if its in pdf you will have to print it out fill it in then scan etc :dapprove:
The free version only lets you view pdf documents, hence the name adobe acrobat reader.
