Ive had my 182 for 2 weeks now and thought I would post my findings, advice and opinions on this forum for other people who have never had one...
1. Shop around - When looking for my car I played dealers off against each other, I went for a test drive in a Honda Type R and the renault 182... I prefered the 182 by far and went to the local dealers.. there I got a quote. Then I went to two other renaults dealers with this quote and told them beat it... I even went back to the Honda dealer and showed them what I could get.... I got massive discounts this way and ended up paying about 12k (first owner).
2. The car does not come with a spare tyre, I asked two dealers about this and one said ts because of the exhaust system going down the middle of the car and the other said it was now Renaults policy not to do spare wheels.
3. Instead of a spare wheel you get this foam that inflates the punctured tyre and fills the whole... this is only temporary... ive not tested it so cant give you my view on this.
4. I am 6 foot 3 inches and find the driving position a little hard going, the steering wheel is about 1-2 inches too far away for me and as a result I have to move the seat forward a bit too far, this in turn effects my clutch control... The steering wheel can be moved up and down but not in and out.
5. The driving seat although movable is still a little high for my taste.
6. You adjust the back of the seat using a handle rather that a twiddly nob (no giggles please)... this I find makes it very hard to get the seat just right.
7. When I first got the car it felt like it was going to stall when idle.... this has got better as I have worn the car in.
8. The engine in my car is not always smooth sounding, sometimes I can hear a noise (just my old astra when the tapets got loud).. it does not always do this.
9. When pulling away when I first get in the car I feel a quick thud or bump coming through the break pads, this only happens when the car has been idle and off and ive been told its to do with the ABS and that its fine.
10. The suspension is very tough and bad roads can sometimes make the ride quality very unplesant... its a sports car though and you expect this.
11. The car drinks petrol.... even when driving miss daisey!
12. The car is fairly noisey inside (but can sound good)
13. I find you either have to have the stereo on 16 volume or above for it be loud enough, below and it is jsut too quite.
14. The speakers lack bass
15. There are diffirent views on wearing the car in, when I first got it I found the temptation to go fast too much... I phoned a few dealers... some of them said not to worry and drive as I want while others said take it easy.
One dealer made the best point though, ive only got the car for 3 years and its under warranty and they test the engines before going into the car.
Ive done 350 miles now, the first 100 I didnt go over 80 mph or about 4 rpm.. after this ive pretty much drivin it as I want... ive still not gone faster than a ton and ive not had the engine at high revs for long periods of time.
I can feel the car getting looser everytime I take a drive.
16. This car is fast ! ... I raced an old RS 2000 escort the other day and absolutely murdered it... the guy could not keep up and when we got the corners he jsut faided away. Ive also seen off an older version Honda type R and had some fun from some traffic lights against a new mini cooper S.
17. The steering is very heavy.... but just right when you get going.
All said and done this car is not a car .... its a go kart.... and I love it.
I am lucky, my partner has a Mazda 6... the steering on that is so light you can blow the steering wheel to take corners, everything about it is right...However it does not have character.....
If you want a very fast car that makes you smile when every drive it then go ahead and get one.... if you like your comfort and you want a car you can drive for 10 years then dont bother.
