discs and pads all round standard or uprated 1s?also when u change the front discs should i get the wheel bearings done at the same time?and how hard is it to do your self cheers
AFAIK no real need to change the wheel bearings when changing the front discs. This is just the case with the rear discs.
Personally, I think the standard discs and pads are very good, but its up to you if you want better ones. Ill be getting a K-Tec Big Brake Conversion in the next couple of months;
I think its an easy enough job to attempt yourself. Only problem might be if you get some rear discs without new wheel bearings already pressed in, as I believe they require a fair amount of force to get them in.
