Advice needed
  White APE
I spent the best part of 3 1/2 hours cleaning the car today.
I used the jet spray to rinse the car. then washed using AG shampoo with washmit. Then rinsed with jet again. Then gave another once over with wash mit and again rinsed off with jet. Used megs hot wheels on the alloys. and then put on some tyre dressing. Used SRP and then AG bumper care on any black bits. Then gave the car a waxing and then polished the glass.
These are the results...
Problem i had when washing was that the skirts and sills were filthy. Had black $hit sprayed all up them. Thinking it must be tar from the roads. After ALOT of washing and killing me arm in the process i managed to get it of the lower part of the door and skirt but under the sill is filthy.
What can you guys suggest i can used to shift it?
Matt
  182
I had exactly the same problem.
Tried several tar removers much to no avail.
Advice on here was the Autosmart Tardis, and good advice it is. What a difference.
