advice needed!!
Car  225 & Audi S4
I have noticed that i have a weird noise coming from the rear left side at the back, especially when i go over bumps ( not at high speeds sensiable ) it sounds like a knocking noise, if i drive on straight roads its fine, i have checked under the car no problem, but suspect the supension not sure, is this normal please help !!!!! :(
Rear shocks are prone to leak very early on with the 182. the 172 normally last 21k miles!!
You will hear a clonk went turning into sharp corners etc. covered under warrenty if its hardly done any mileage.
Craig
