Advice on induction kit pleaseee
Car  clio
I have found this on eBay would it be any better than standard filter box with itg panel filter? Item number 390490291369. Thanks
It'll make a good noise for sure, louder than your current setup, as for power none of the induction kits make any real difference.
With my 182 on track, with the filter behind the headlight (don't know where that will fit on the 197) I get approx. 1-2degrees hotter air intake temp vs. a similar clio running the standard airbox and ITG filter.
(Temps used to be pretty much identical when on the same airbox)
