Hello guys
I have a problem with my Renault clio 3 rs 20[SUP]th[/SUP] edition.I have fitted a free flow exhaust system and I have removed both catalysticconverters and I fitted a cat fooler. When I did this there were no troblecodes found on the bosch diagnostic machine, But when I took it for a drive Inoticed that when I accelerated from a still position at full throttle therewas a flat spot or a mifire and then after that it accelerated properly. Idrove a for a day and it still happened. So I removed the cat fooler and putthe lamda sensor back, but it still has the same problem. Could you maybe giveme advice on what could be the problem or if you have a solution for this.
Thank you.
Thank you.
