advice on scissor lift
  clio 172
Hi All
Need advice on scissor lift
Want to purchase one just wondered what everyone is using and if anyone has one of the following :
Mid Rise Scissor Lift, Vehicle Lift, Car Lift, Eurotek MRS3
Mid Rise Scissor Lift, PLatinum MSL3
So anyone got one of the above are they any good or any recommendations for others ?
RichValver
  Clio 16v/172 daily
Been thinking about something like this for my workshop too. What are they like for working under the car etc if anyone has any experience
BashRacing
I'm looking too and watched loads of videos on youtube,
they look ok for 50% of work but they're an awkward height if you want to pull the gearbox etc as you're half way between knelt down and stood up
this is another option if in a standard height garage
I think i'm going with one of these and counter sink it in the garage floor
botfch
  Clio 182
If it’s a house you plan to stay in a while then digging a pit so you can stand up would be more useful imo.
jameswrx
Trouble with these cheaper lifts (even the two poster above) is they’re half height where you’d want.
I’ve only just realised that on the two poster so must tell a customer of mine. He reckons he found one for £1600 fitted, must be a half height
Mertin
  Ph1 172&Ph2 172 Cup
Your still very limited with a pit especially for any suspension work or working in the wheel arch area. Pits only good for oil change and exhaust work imo. You'll still end up working on the floor alot
Dom_capper
  2012 Renault Clio
Yeh it’s hard to get the wheels off when using a pit as you’ll usually have a big hole in the floor where your jack and stands want to go.
Mertin
  Ph1 172&Ph2 172 Cup
Can sometimes get round it by fitting a jacking beam / box section steel to bridge the gap and give you something to work off of but again it will eventually just get in the way of something
