Advice on wheels please
VIICarCare
Car  255, 230, 172, R26
Tried to get my front wheels off today, bolts all taken out but the wheel wouldnt free. Had a good go at getting it off (boss too) but its really stuck! :dapprove:
Help please :(
Large block of wood on inner edge & large hammer, hit the wood:o
Or sit in front of wheel & kick tyre, with weight of car off wheel.
i just kicked the sides of the tyres on either side until they came off!
had this hasstle with my dads beemer. got a sponge or a cloth and put it on a spoke then had to wedge a bar in and prise it off!
failing that, jack the car up and turn the steering fully left hand down. then lie down and kick it off from the inside.
one of them will work
DO NOT KICK!
Had the same issue with mine. Flat bit of wood on the inside of the rim. And a BIG hammer! Once you get them off. Ensure copper slip is put on the hub.
or use a rubber mallet and keep hitting behind the wheel, can sometimes work from the front but much better from behind the wheel
well she had a service in oct but not sure if wheels came off :dapprove: Every time i've had my wheels off i've always put plenty of copper grease on the hub.
Cheers boys, will have a go next weekend :approve:
