aftermarket guages
  Renault clio 16V Dimma
Got some aftermarket gauges. Oil pressure, oil temp. Just wondering if anyone has any ideas on the best location for the sender units.
I know you can get sandwich kits between filter and block but it seems pretty tight, especially with the pressure sender which is about 40mm in diameter and 35mm deep.
Any other locations where there are blank oil galley plugs or the like?
Anyone had experience with fitting aftermarket gauges?
