clio 172
				Hi lads,
I'm sure this topic as been covered a bazzilion times but I'm going to play the "I couldn't find it after loads of searching" card which I've been doing loads of but cant seem to find a straight answer. Recently purchased a new OMP steering wheel for my PH2 clio 172. The wheel came with this horn:
My question is from the black/red wires that the original horn uses what wires go on to what terminals on my new horn?
I've read threads that the Spring clip on the top left of the back view of the horn needs to be removed to prevent shorting and other threads sayings you only need to wire one wire to horn, but which one and to what terminal on the new horn?
I know an easy solution is getting a PH1 stalk with the horn already on it but I'd rather wire this horn up instead
Any help is greatly appreciated
