Aftermarket pedals
Car  Rb 182
Can you put them on a Mk1?? I Have a set for mines but the acc pedal is like a stick rather than a pedal??
Pics please
they are ripspeed ones, i just took off the old ones and the new ones screwed straight on, ill try and get some pics up soon. i did have rage pedals for a while but they are rubbish because they dont screw on they just use a little bit of metal which holds it behind, but they dont really fit a clio and my clutch pedal fell off while i was driving lol
got some really quick pics, camera isnt very good though and the pedals are dirty, but its just so u can see
is that a lil neon i see there :rasp: . ur accerator pedal looks a bit high
it was taken at an angle so it looks further back. it is a neon, but its crapand it doesnt ever get used. ill probably flog them on ebay cos they only cost around a fiver lol
just a tip but i wouldnt get chrome ones as they get really slippy when when or muddy! brushed aluminium tends to grip better! :D
Thats the ones i have, sparco to match me knob ;)
I just made some new pedals when the ones on my 172 wore away on the edges .
Excuse the sh*t on the floor and the dirty pedals , the car needed a good clean .
My plastic/rubber grip from my clutch pedal has just fallen off in my valver. I want to get some aftermarket pedals, but do you *HAVE* to drill holes into the pedals to fit them?
I want them to be sturdy so ideally i'd like to attach them with screws/bolts, just wondering whether the holes are already there?
You'll have to drill the pedals underneath the rubber grip mate , and it'll be a right b*tch to do , you'll need a good sharp drill bit(s) , a good powerful drill and lots of sweatin' in this weather , lol .
Sod that... i really don't want to drill through my pedals, i never make any irreversible modifications to my car, i feel guilty for some reason, lol!
Are there not any pedals i can attach without drilling that won't fall off after 5 minutes?
^^^^ You could probably make some like i did out of aluminium sheet , whereas i pop riveted mine on in the original holes , you could epoxy resin them onto the original pedals underneath the rubbers .
Probably cost you about £15 tops for both the ally sheet and expoxy , plus you'll have enough aluminium left to make at least another 3 maybe 4 sets :)
The original Renault pedal covers in the 172 / 182's are 1.5mm thick , i used 2mm .
I've just ordered some from fleabay, aluminum ones but i beleive they have to have holes drilled for them to stay on.
