Air bag and service lights
  Renault clio
Hi. Help needed. I have had the clutch repaired on my 2010 clio. On picking car up the air bag and service lights are on. The garage are saying nothing to do with them and it is just a coincidence. Has this happened to any one else. Bit annoying having to pay out again.
  2001 megane coupe
The most obvious culprit is probably going to be the connections under the drivers seat, as the mechanic probably would of moved it around to get it in a position to drive / test the clutch ?
Only way to see properly would be to get it on a clip / icarsoft code reader. (other makes avaliable - very few, but there are a couple)
  2001 megane coupe
Yeah airbag light will be now, i think it changed a couple years back.
Did they at least tell you what the problem was ?
