***Air Conditioning Fuses** Where
D
Dynamic Devil
Hi,
My air conditioning doesnt seem to be working. Does anyone on here know where abouts the fuse for it is, so that I can check it??
tHANKS
KDF
  Audi TT Stronic
how do you mean not working ? does the AC light come on ? and the fans blow .. but not cold ?
cause if so then its more than likely the system needs re-gassed, my 172 was only 10months old and it leaked all the gas, 2 pipes had to be replaced and it had to be re-gased again.
Could be that, if your fans have stopped working then check the fusebox by opening the passenger door and pulling off the cover on the side of the dash.
NOTE if the aircon needs re-gased you wont hear it click when you switch it on, or hear it spin down when you switch it off.
  Elise/VX220/R26
fuses are on the passanger side m8. Open the passanger door and they are in a little panel against the side of the dash. Aircon fuses are near the bottom.
D
Dynamic Devil
Thanks for your help.
Yes that s the fans work ok and the AC orange light comes on but it is just blowing normal temp air. Not cold atall.
What you reckon?? Take back to Renault??
Rich-D
  E90 LCI 330d
Sounds just like my mates mk1 172 that I am driving (reads sweating in) at the moment...
Apparently it needs re-gassing and checking for leaks, so its going in on Wednesday.
