Air filter adapters
Car  RB 182 cup
Hi guys, I've got a mk 2 ph 2 clio 1.6, when I take the standard air box off the connector is like an oval shape instead of the usual circle ones where you can easy connect a k and n for example, does anyone know if I can buy some sort of adapter so I can fit a different air filter?
Thanks Blane
Thanks Blane
just get a K&N that is made for your car? :P
All the k and n's on eBay, the picture doesn't show an adapter so don't know if it's gonna come with one
If you buy a car specific kit it should come with all the parts needed to fit (if you still worried message the seller) If you buy just an air filter than that's what you get lol
The aftermarket induction kits for the 1.6 engine start at the throttle body, the throttle body on your engine is at the back. You will have to take the oem air box out which holds your panel filter, else you would have 2 air filters lol.
As you can see it starts at the back of the engine:
