air filter or induction kit??
  Renaultsport Clio 197
hi all,
what would you guys recommend fitting - replacement performance air filter, or induction kit??
cheers.
  Looking for a ph-quick...
Replacement filter as its gettin warmer, Induction kits although they sound great will just cause heat sink.
  Tin Can with wheels
hey,
If your after performance then induction kit. I found the induction kit increase the
throttle response and shaper acceleration, also you will have a deeper engine note when booting about.
Regards
  scirocco r
i have a applo k&n kit on my clio197 it sounds the dogs and seems to pick up a bit better.
this is a pic off the kit on the car.
P
Paul Common 666
Ive just fit a BMC CDA to mine, sounds lovely and it gives a slight increase in performance, not much tho! Get a closed air one with a cold air feed tho! If you were thinkin of k&n's and the like you may aswell just get a panel filter!
thanks for the help guys, still considering the options, i had an induction kit on my last two cars, but i had read that panel filters work better 'cos of the induction kit taking in the heat from the engine, and i wanna go more for performance than "just noise" this time around.
medici999 i've pm'd you ref. your viper.
  Clio 172 mk2
K&Ns are good along with Green and ITG
I've got a Green panel in my 172 which is pretty similar to the K&N....I chose it due to reccomendations from friends who run/tune Subarus and use them frequently without problems.
Also cheaper than ITG:D
  Polo + Micra
get a bmc cda like this ;)
you're not suddenly going to get colder air if you only get a panel filter + the oem induction setup on the 1.6 is really bad
anyone got a part number for the BMC?
i havn't got a lot of money at the min tbh, aren't they 'bout £200 or summit?
  Racing Blue 182
I had a powertec induction kit, got rid of it, the noise was good but the engine just didnt feel the same, wasn't as responsive and felt a lot looser (if that makes sense). Ive now got a ITG panel and would highly recommend and will actually save you £££'s over the years.
think i've got my heart set on a bmc cda now, that kit seems to be the best value for money.
